Mike issue on 1500
Tom Stahl
The mike is not working on the 1500. Mike was tested on a known good 1500 and works fine. The voltage for the Mike bias and the PTT both check good at the back of the connector and at the front of the cable using a breakout cable for testing. Soon now feel that the connector and mike are fine. Using the test capability (control shift P) the Mike and PTT IO both indicate failure. (Note: I did not have the super duper flex test box, so that may have negated the tests both everything else passed. Radio transmits just fine on digital with input from FLDigi so the radio is all working except the Mike input. Any thoughts from the community?
Thanks, trying to help my Brother fix his flex that I talked him into buying
Tom WB8LDW
Tom WB8LDW
If the top of the f1500 is hotter than usual, then the audio ic is kaput. It will need changing
no its been on all day and is cool to touch.
you will be better off sending it to your local flex agent for repairs as its all surface mount components, well most of it anyway0
I have changed this post to a problem topic and converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
