WSJT FSK441 Meteor Scatter Setup Help
Cal N3CAL
Anyone out there using there Flex 6000's for Meteor Scatter on 6m? I've been seeing alot of signals on the waterfall lately and it caught my attention so I finally decided to try a new mode! I downloaded WSJT v10 and have it up and running. I've been listening on 6m and actually have it decoding pings but I'm unsure of what my proper settings should be? Here are a few questions :
1. What should the RX bandwidth be? (I'm currently set at "5.0k" DIGU)
2. What should AGC be set at? (currently set at "Fast")
3. I cant get PTT/CAT to work? Seems like VOX is the only way to TX?
4. Do I need to set High and Low Cut for TX. It seems like my TX signal is too wide?
5. What power level do most folks run? Ant here is a M2 3 Element Yagi.
Anyone out there that could pass along any info it would be greatly appreciated. Maybe someone would like to try and work me for my first QSO?
Cal/N3CAL
Cal/N3CAL
Good morning, Cal. Have made many ms contacts with my 6500. It is a blast! 1) DIGU bandwidth 3 kHz, although you could manually narrow it a little more. 2) I run with AGC off on all digital modes. Fast works, but I prefer the faster response time and resistance to pumping using no AGC. 3) PTT works. Set the CAT port in WSJT. VOX is fine, though. 4) No. watch your ALC, though. The FSK441 signal is fairly broadband, as digital modes go. 5) Running 3 elements and up to 500w here. Started with 100 and a dipole. More ERP is better (to a point). Enjoy!!0
Thanks for all the info George! It's very exciting seeing all the various pings on the waterfall!
73 de Cal/N3CAL
George,
Does my TX signal look ok? Not sure but to me it looks too wide??
Cal/N3CAL
I had to go to wsjt9 and manually set the sound and ptt ports to get it to work in fsk4410
You look to be in the ballpark, Cal. Mine is attached for reference. Same scale, but I do run lower power from the Flex since it drives an amplifier. See you on the radio.
- 384 Community Topics
- 643 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
