Maestro external PTT
AB9UU
Radiosport hand key will key Maestro but not Amp. I have a Radiosport Heaset which when I press the transmit button on the headset will key both the maestro and my Expert Amp. When I connect the Radiosport Hand Switch, only the Maestro keys. Any ideas or setting I need to change. In the house I have DDUtil but am planning on running mobile only connecting the Maestro to a Flex 6300 I will have in the trunk with an ALS 500 Amp.
From the manual I see this:
PTT OVERRIDE WHEN OPERATING LAN REMOTE
When operating in a non DIGx mode, using a hardware PTT such as the RCA PTT input on the transceiver back panel or the transceiver front panel microphone PTT will override the Maestro PTT.
This feature is provided to allow an operator at the transceiver to override the Maestro input with a PTT switch connected directly to the radio.
Does this mean I need to have the hand switch connected to the transceiver and not the Maestro. Sort of defeats the purpose - doesn't it?
Can you tell me where each of the two devices are plugged in (which device and port)?0
AB9UU, this might not be the case but it happened to me.... make sure the jack in the maestro is fully inserted. I was having a similar problem on my first day of operation with the maestro and it was due to the plug not being all the way in.0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
