Choppy CW with N1MM Logger+ and SSDR 1.8.3
William Hein
KL2A and I are running N1MM Logger + multisingle in IARU contest today as W0LFA. We are using the current version of Logger + with a Flex 6700 and the latest version of SSDR 1.8.3 along with latest SSDR CAT. Logging and SSDR PC is running Windows 7 Pro SP1 with Intel Core 2 2.13 GHz CPU with 2 GB RAM Logger + is interfaced for CW to SSDR CAT COM 6 with Port Protocol Winkeyer, Port Type Serial, and Serial Port Type Serial FlexVSP. Jon KL2A has noticed that when he types in the logging window while the Flex is sending CW generated by Logger + the sent CW is choppy. So, we can't enter callsigns or exchange during TX. Is the problem the way I set up Logger + and SSDR? Or just an underpowered PC? 73 Bill AA7XT
Go into the Task Manager and set Logger to low priority; right click on the Logger Task and select priority and select low. You can also set SSDR priority to High and if all this fails can try SSDR as priority Real Time. With performance monitor check CPU utilization to see if any uninvited apps are **** up CPU cycles.4
This seems to have worked, thanks!0
Yes, thank you! I had the same problem with the N1MM+ voice keyer.
Bill I have not tried your solution but it sounds like a winner.
William and Bill and Tim, I just noticed a feature w/in N1MM+ and it may cure both of these but have not taken the time to play with it yet. Go to config tab...autosend threshold...enter value. I noticed, when using SSDR winkeyer emulator, if I selected enter (w/ enter sends message enabled) and only the prefix of the call in the entry window stutter would take place and if more of the call was entered then no stutter (that was with a figure of 0 for autosend threshold. I think if I had used a value of 1 or 2, then there would have been zero issues with stutter, however, my typing skills **** so I currently use my external winkeyer which will not stutter w/ just the prefix of the call entered. I do not use phone much.0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
