hear others quite will but can't make any contact digitally or with phone. what's wrong?
James Madden
on 20 meters or any other frequency i can hear lots of people but when i try to make contact they never respond. is there some kind of problem with my transmission?
thanks
Jim
thanks
Jim
Wattmeter reading okay? If there's propagation to Las Vegas from your end, I'm happy to meet you on the air..
Have you listened to your signal to see if it sounds OK?0
Make sure you are on the transmit slice indicated by the red Tx Make sure your mic setting is set right. Balmifmusing balanced and Mic if using front Done there a few times each Mike N9DFD I1
It's the life of a killer receiver. People always refer to those with amps and big antennas on deaf radios as an alligator. I have coined a new term to describe my situation with a 6700 on a wire antenna: "Dumbo - All ears, no mouth."0
an easier way to test is to use JT65A, , call CQ and then check PSK Reporter. It will map who heard your CQ. https://pskreporter.info/pskmap2
Thanks everyone so much. Ill try these suggestions. Jim0
Maybe sunday after 2pm? What frequency? Thanks Jim0
Whats the best way to listen to the signal? Do i need another receiver? Jim0
- 384 Community Topics
- 643 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
