hear others quite will but can't make any contact digitally or with phone. what's wrong?
edited October 2019 in FLEX-6000 Signature Series
on 20 meters or any other frequency i can hear lots of people but when i try to make contact they never respond. is there some kind of problem with my transmission?
thanks
Jim
Welcome!
  • Member ✭✭✭
    edited February 2019
    Wattmeter reading okay? If there's propagation to Las Vegas from your end, I'm happy to meet you on the air..
  • Member ✭✭✭
    edited May 2018
    Have you listened to your signal to see if it sounds OK?
  • Member ✭✭
    edited October 2019
    Make sure you are on the transmit slice indicated by the red Tx Make sure your mic setting is set right. Balmifmusing balanced and Mic if using front Done there a few times each Mike N9DFD I
  • Member ✭✭
    edited February 2017
    It's the life of a killer receiver. People always refer to those with amps and big antennas on deaf radios as an alligator. I have coined a new term to describe my situation with a 6700 on a wire antenna: "Dumbo - All ears, no mouth."
  • Member ✭✭✭
    edited July 2016
    an easier way to test is to use JT65A, , call CQ and then check PSK Reporter.  It will map who heard your CQ. https://pskreporter.info/pskmap
  • Member
    edited May 2018
    Thanks everyone so much. Ill try these suggestions. Jim
  • Member
    edited November 2016
    Maybe sunday after 2pm? What frequency? Thanks Jim
  • Member
    Whats the best way to listen to the signal? Do i need another receiver? Jim
