maestro wired vs wifi
Norm - W7CK
Is there a way to temporarily turn off the wifi on the Maestro and force it to use the wired connection? It seems that it always wants to use wifi even when hard wired.
One thing I found to be neat is to run the cat5 from the 6500 directly to the Maestro. No computer and no wifi needed. Possibilities!0
I don't have my Maestro in front of me, but you can do this. You don't turn off the wifi, I think you touch the Icon in the bottom right (or left) before you select your Wifi network.
Mike va3mw
Tried this on mine but the Ethernet port is not active. Tried different cables and ports on switch swapping with known good port still no joy. It's like the port is not active in the Maestro. I know it works because we used it on Field Day, I'm stumped
Warren NU7R.
Try a different Ethernet switch. I had similar problem with my Maestro using a TrendNet gigabit switch. It did not like it. Switched it to a Cisco Gigabit switch and it works fine. Dudley also suggested using a 100 MB switch instead of a Gigabit switch. But, the Maestro Ethernet in general seems to me to be rather finicky. More than it should be. But I love teh Maestro. i am sure the guys at Flex will get the bugs out.0
If you go into WiFi and "Forget" your WiFi network it will only have the wired option for connection.
Mine defaults to Wired IP, but after a restart. If I am on Wifi and connect the ethernet it will keep two IPs.0 -
Salvador
I've seen that too. Thanks for pointing out that "should have been obvious" workaround. My WiFi works right up until, it doesn't. I wish it would just prefer the wired connection when it's available. With two IP's active, is it trying to stream using both? or does it default to "Use WiFi when it's available". wired ought to out perform 802.11n WiFi.
73, Jay - NO5J0 -
As far as I can tell, mine defaults to wired network but it is not obvious.. So maybe this could be entered as a suggestion for future version0
We need to be able to turn the wifi OFF. I mean actually turn the wifi radio off. We also need to be able to turn it back on when needed, select a network that we've used before and not have to re-enter the network security key. It should remember this.....
Norm
Agreed, Until we get the ability to turn the WiFi radio off, we will be stuck with workarounds. I don't really know what's is and isn't possible, But is it necessary to have two connection choosers one for all things WiFi and another for wired. Wouldn't one chooser that lists all the available connections both wired and WiFi in one list, lets you select one, and then actually uses what you told it to use for that sesssion make sense. The WiFi connection selections should just learn and remember the security keys, unless told to forget them. the WiFi icon in the lower left ought to be capable of toggleing the WiFi radio on and off. But when I select a wired connection, I don't want it using anything but wired. I haven't had enough time with the Maestro to really figure out what I want yet.
Flexradio needs to know what we want before they invest any time into creating code that doesn't do what we want. That can't later be undone, with out introducing problems. They have mentioned that they aiming for more frequent releases. Which means they need our input now not later. Discussing the pros and cons of all our ideas doesn't have to be seen as unwanted interference.
No Harm, No Foul, Intended!
73, Jay - NO5J0
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 29 SmartSDR+
- 6.3K SmartSDR for Windows
- 415 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 222 FLEX-8000 Signature Series
- 928 Maestro
- 902 Genius Products
- 325 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 982 Third-Party Software
