Antenna Genius and WWV
AH0U
AH0U Member
edited April 2019 in FLEX-6000 Signature Series
I am using the Antenna Genius with my 6700 and it works great!! Today I wanted to listen to WWV and I clicked on BANDS and then WWV and the rig went quiet... it was then that I realized the Antenna Genius had no antenna set for WWV or GEN so I tried  to assign my 20 meter beam to WWV but there seems to be no WWV or GEN in the pulldown menu on Antenna Genius.... Anybody have an idea how to do this???
tnx  AH0U
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    edited December 2017
    You should send the request in to Dragisa 4O9ITT  to add to the next release.  The best way currently is to use an antenna on the 6700's  RXA or RXB ports.
    I am using this same configuration and cannot determine any other way to assign one of the Ant1 or Ant2 ports.
    Regards
    Larry  K1UO
  • Andreas Junge
    Andreas Junge Member ✭✭
    edited April 2019
    Try "None" as band, switch to WWV and then click on that antenna port in the AG app window.
