winmor tcp/ip port number and flex
James Madden
trying to configure winmor so I can use RMS Express. an error message pops up saying the port number is in use and can't be used. what port number do I use
Hi James, Here is my setup - see below. Using 6500 w SmartSDR. Hope that helps! John AF3K
The port number that RMS express refers to if probably the WInmor Virtual TNC command port and has nothing to do with Flex. See WInmor winlink setup>Winmor TNC setup.. Mine defaults to 8500. I would suggest closing and restarting the PC and RMS espress.. If that does not resolve the issue you can choose a different port number ( 8550 ?? ) and restart RMS express.
RMS Express does uses CAT/DAX ports to connect to SSDR not tcp/ip ports.
AL, K0VM
sorry stoill no joy. and it appears you aren't using the latest software.
please see the 2 attachments.
I searched for winmor winlink setuo and nothiing related to setuo came back. What lonk are you referring to?0
regardless of what port number I choose I get an error saying that perhaps the ports are in use.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
