winmor tcp/ip port number and flex
edited May 2018 in Third-Party Software
trying to configure winmor so I can use RMS Express. an error message pops up saying the port number is in use and can't be used. what port number do I use
Welcome!
  • Member ✭✭
    edited May 2018
    Hi James, Here is my setup - see below. Using 6500 w SmartSDR. Hope that helps! John AF3K imageimageimageimage
  • Member ✭✭✭
    edited May 2018
    The port number that RMS express refers to if probably the WInmor Virtual TNC command port and has nothing to do with Flex.  See WInmor winlink setup>Winmor TNC setup.. Mine defaults to 8500. I would suggest closing and restarting the PC and RMS espress.. If that does not resolve the  issue you can choose a different port number ( 8550 ?? ) and restart RMS express.
    RMS Express does uses  CAT/DAX ports to connect to SSDR not tcp/ip ports.
    AL, K0VM
  • Member
    edited November 2016
    sorry stoill no joy. and it appears you aren't using the latest software.
    please see the 2 attachments.image
  • Member
    I searched for winmor winlink setuo and nothiing related to setuo came back. What lonk are you referring to?
  • Member ✭✭✭
    edited December 2016
  • Member
    regardless of what port number I choose I get an error saying that perhaps the ports are in use.
