1.7.30 locks up
DaveC
Just had my 6300 lock up. SSDR froze, and a steady beep from the speaker. I had to hold the power button in for about 5 seconds to get the radio to reboot. Running windows 10 radio is in CW mode. 1.7.30 has been running OK. I installed it about when it was released. I usually run the radio about 16 hours a day with no problems.
Don't expect a fix, just reporting a lock up for the benefit of everyone.
SOAP BOX TIME:
BTW when I did a search on the above title I got over 5000 hits. I am not going to read 5000 post.
Very hard to find answers to problems that may have already been addressed. Makes for a poor user experience.
I am a little disappointed in the quality of the software. It seems like things that use to work now have problems and reported problems have not been addressed. It also seems like Flex is more interest in the networking of the 6000 so someone sitting in their backyard can operate their radio with their iPhone, rather then worry about the actual quality and reliability of the radio.
This is my opinion only. The service people have done a great job. Have always help when problems a raise.
SOAP BOX TIME:
2
Tim posted in another thread that this is being investigated. Maybe a fix will be available soon. I have not had the problem here since turning off DAX and shutting down FLDigi (which also disconnects the CAT connection) a week ago; maybe there is a connection (no pun intended) between themy.1
Have had it happen myself.
My hope is now we have MAESTRO ( I HAVE ONE ) FRS will move on and work on software issues. I purchased my MAESTRO so I would have KNOBS, I DON'T need all this networking stuff, but I DO need a radio that works as it should.
Lew
N4CO4 -
Had same problem - 3 times this weekend in 4 hours of operating time using 6700 and PC interface. Is there a log file or something we can look at to give a clue?2
Disclaimer: there is no way I am going to install 1.7. Nor will I install any release for, likely, at least a month after release to gauge it's in field reliability. However, I have had that problem and it was RF induced. To that end: Ensure you have a solid single point ground. Ensure you have a very short path to earth. Add ferrite where there are long runs and at the radiator end of your coax. ARRL has good articles on the subject that do not involve product marketing.1
Thanks for the thoughts. Its probably not RF as it is on receive and just locks up. Also, same setup for 6 months plus without this issue with no cabling, ground, antenna changes. Guessing it is software related.1
went back to 1.6.21 - it may have problems but at least I can run it month after month without it failing on me.
But I do not have a maestro and I do not do remote stuff - so it is an alternative for me.
All my hopes for them to chase out the nasty buggies for the next release.
Cheers
Hmm, I agree, tough to have an RF problem when in receive only.1
I concur Walt. It is my sincerest hope the last point release of 1.x is a bug squashing effort only.2
not even got my radio yet ( comes tomorrow ) regretting buying it already .. at THESE prices it should be 100 % rock solid !1
Same here had it happen three times! Disappointing to say the least0
Hi Rob.
In just over 12 months of flex ownership, I have had this happen exactly twice (my 6500 is left on 24/7). Whilst it is annoying when it happens, I don't think that is too bad when you consider the complexity of the equipment?0 -
<<<< at THESE prices it should be 100 % rock solid ! >>>
I suppose that would be a reasonable expectation... if you were purchasing a rock ;-)
I actually was running 1.5 before upgrading to 1.7. 1.5 was very reliable and I knew what issues it had. I only upgraded because I did not want to get too far out of date. I skipped 1.6 all together.
BTW I was not transmitting, only listening. So NOT an RF problem. I have run many hours of CW and JT9 with no issues.
Thanks for comment.1 -
I agree 100% . That has been my gripe with them all along. Get it 100% bug free and work on options. Instead it gets put into bug tracker for further investigation and "possible fix in next version. I am disapointed in my maestro after waiting almost a year for it. It is sitting in the cabinet right now. Of course flex isnt listening.1
perhaps, im just a bit bemused be certain aspects of Flex products.. I will better judge once I own one .. UPS **** couriers ..0
While I don't drink FRS Kool Aid, or any other brand Kool Aid, I think for most part FRS does a good job with product. I do find it a bit disconcerting that so many problems / issues / enhancements were side lined while working to get Maestro developed and released. My Maestro works, for most part, as I expected. Now if FRS will resolve cw latency and get Maestro WinKeyer to link to external programs so I can junk my external WinKeyer I'll be impressed.
Lew
N4CO1 -
Well you can make a lot of contacts with a rock, if your aim is any good. Just remember, that the harder you throw, the more likely it will be that you will be able to retrieve your rock. and then use your rock for the next contact.
When I started out in amateur radio, I must have misunderstood the importance of all the rock throwing which I see more and more amateurs embracing as best practices.
Because of this I've had to really work on my ducking abilities.
That's what it's all about bigger, better, and faster rocks.
SDR == Software Defined Rocks
OK, I get it now.
Rocks ... Because we really can't, just all get along.
73, Jay - NO5J2 -
you must not get out much, its a British expression meaning something does not **** out and crash at t the 1st sign of hard work..0
Open a support ticket with Flex. They helped me with this issue. My lock up was an easy fix.0
Rob
How very British of you, thinking that I have such a limited understanding of the English language. Maybe it's you that needs to get our more.
73, Jay - NO5J
For what it's worth I'll contribute my two cents. I love my flex 6500. I think it's one of the best radios I've ever owned. I guess I just expect more out of a $4000 radio. All that being said I couldNt be happier.and I realize SDR is still in its infancy and some re and I realize SDR is still in its infancy in some respects. That being said I guess we should all expect some bumps along the road. I think the people at flex are doing the best they can.2
I did this and was told it was a software issue. They then converted my ticket status to "resolved"0
Being that it was an easy fix, that should be also easily explainable, eh?
This is my main gripe with FRS support, "resolved" generally means, "we know what the problem is and will fix it soon".
Personally I would prefer that tickets with the same problem are given another status so that people with the problem can be kept informed with progress on a fix, maybe even then providing a test build but FRS don't seem to work this way?0 -
Good point Walt ! Why NOT share fix with rest of us ? Not much help around on weekends, not that I expect there should be.
Lew
N4CO0 -
whatever jay, whatever,, your the passive aggressive one who just could not keep it shut.. not me..0
yep, that's an old trick..0
Everybody remain calm its all good0
Whether it is a 15 person staff, a 30 person staff, or a 13,000 person staff; there is only so much you can do in a day, week, month, quarter, year. I've worked, in software engineering, in start-ups and very large organizations. Projects need to be prioritized. The smaller the company, the more revenue focused, they have to be. That said, allowing the bug list to grow very quickly leads to an unmanageable situation. I am sure FRS is keenly aware of that. I would also suggest having a software induced product freeze up is a sev-1 bug, especially compared to having nicer decorators on graphical controls, the later being a request not a bug.
Rob
Well you started it ...
Didn't you.
Perhaps you can figure out how to stop it.
73, Jay - NO5J0
- 315 Community Topics
- 574 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 365 SmartSDR for Mac
- 251 SmartSDR for iOS
- 243 SmartSDR CAT
- 176 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 121 FLEX-8000 Signature Series
- 855 Maestro
- 50 FlexControl
- 804 Genius Products
- 279 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 428 Remote Operation (SmartLink)
- 132 Contesting
- 695 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 920 Third-Party Software
