Internal noise on mic input Flex 6500
Ken
I really think the in the TX passband garbage seen on the panadapter with DEXP disabled is just inaccuracy. My mic audio thru the monitor, using the Full Duplex trick, or Recorded and then played back, is always dead silent unless the DEXP is disabled. It sounds like what's described as full quieting, I've always thought that even full quieting is probably visible on a spectrum analyzer, as almost but not quite a 0 dB level. It may just be that the panadapter which is useful when observing received signals is not the best display to use observe transmit audio.
What I'm really interested in is confirmation that that noise on the panadapter, (that the DEXP removes) is likely a display anomaly.
The thread I linked makes me think it is.
Possibly being misinterpreted as something it's not. I don't expect to ever see the noise floor flat line no matter how high I set the averaging. So why worry about random digital noise on the input of the panadapter input tap. The difference between 0dB audio and 0.001 dB audio should still register as a 0.001 dB peak on the display, even if it's a meaningless peak because it never registers as anything but 0 dB at the input of the PA.
How loud, or quiet, is quiet?
Is my zero less than your zero?
How perfect, is perfection?
I think it is, what it is.
Good enough for Amateur Radio!
Might even be better than that.
We could just be satisfied.
Even with on air playbacks of my mic audio recorded on another 6XXX my mic audio sounds full quieted or at least as full quieted as the mic audio from the other 6XXX.
Which is better, worrying about nothing, or being happy, that it's nothing?
Worth thinking about, when you think about it.
73, Jay - NO5J
And yes, the two Jays posting in this thread, are really two different people, even I get confused.
That is why I like the DEXP. It keeps things quiet. If I set it right, it even quiets my breathing sounds from the mic!0
I have the MIC input noise issue here as well. 200Hz and its harmonics only on the mic input. Noise goes up and down with mic gain or the +20dB in setup. The dexp helps, but is only masking the problem. ACC input looks clean as well as PC audio. It's NOT an RF issue, unless it's internal to the flex.
John KB1YFD0
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 156 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 123 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 696 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
