SteppIR with Maestro?
good question
my guess is the DDUtil - SteppIR interface will not work but I hope I'm wrong0 -
DDUTIL is how you need to,do it now. It runs on your main PC and works 100% with Maestro There is an enhancement request on the books to enable external device controls But don't know when it will happen as there is still a lot of other enhancement stuff to do first.1
I'm using DDUtil running on one of my shacks computers (sitting next to my 6500) connected to my network which controls my Elecraft KPA-500/KAT500 and KPA-100A. It still runs and works fine while using the Maestro connected to my 6500. If I want to see what DDUTil is doing I have to remote a laptop into that shack computer.
Cal/N3CAL
Thanks0
I have a Maestro on order. I was assuming SmartSDR CAT would still run on the shack PC driving my flex controller. Do I still need DDUtil?
Jeff - AK0DX
Running 6500, Maestro, Quadra, DDUtil(v3.2.4.04), 3el SteppIR with SDA100 controller. Using Passive Listener in DDUtil the SDA100 controller follows the Flexradio if connected via the Maestro or if SmartSDR is used on shack computer. I also have setup the band data setup on DDUtil so band changes on the 6500 are changed on the Quadra.0
@Jeff Assuming u mean the SDA100 SteppIR controller. Yes you need DDUTIL to Synch the SteppIR0
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
