Poor/Bad Transmit Audio Flex-6300
2»
  • dan
    dan Member ✭✭
    edited March 2016
    That's great Howard. I'm using the Logitech right into the desktop. What mic profile do you use with your Logitech? I'm using *default FHM-1. My signal quality reports on my 6300 are my signal is stronger than my audio. However, I pushed up the mic gain slider up to 55.  I'm trying your EQ now. 73 Dan
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited March 2016
    You also need to set mike gain to +20DB in the. Mike setup screen
  • Don Stefanik
    Don Stefanik Member
    edited June 2016
    I have the 6300 with Heil 781 mic.
    Everyone said I had way to much base. I even heard myself on Youtube and could hardly understand what I was saying. I found someone who was willing to spend some time with me fine tuning the q settings. Here are the final #'s we came up with.
    63/-10   125/-10  250/+2  500/-4  1k/0  2k/+10  4k/+10  8k/0
    Now I get lots of great comments on my audio.
  • Stu McLoughlin
    Stu McLoughlin Member ✭✭
    edited October 2019
    What was the low and high cut that you used?
  • Mike NN9DD
    Mike NN9DD Member ✭✭
    edited December 2016
    I use 150 as my lo,cut
  • Stu McLoughlin
    edited June 2016
    Thanks! - assuming 2900 as the high?
  • Mike NN9DD
    I use 3200
  • Stu McLoughlin
    edited June 2016
    Great thanks. Apprecaiet it. New to Flex and a minefield with audio! :-)
  • dan
    dan Member ✭✭
    edited February 2018
    I was going bonkers because my audio reports said my voice sounded like I was in a steel drum with my 6300. Fooled with my computer's audio for a couple weeks. I was using a Logitech headset (on the computer) with one cable for both audio and the mic. That must have been the problem because I went to a more expensive computer headset with two leads and my signal reports are now good.
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    Lol, it all starts with the audio input. Remember the mic must be able to pick up your hole voice, top to bottom. Then after a little EQ it could sound very smooth. Glad you got it...
