Maestro problem with straight key
for stright key, Use a 1/8 TRS onnector then in the Maestro MENU>Phone/CW menu, set Iambic Disabled and Swap(DASH/DOT) enabled. This should allow you to use a straight key on the tip of the connector.. I think you will need to NOT use a tip and sleeve connector ( the ring needs to be open circuit).
AL, K0VM
Thank you! It is work!0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
