Maestro problem with straight key
for stright key, Use a 1/8 TRS onnector then in the Maestro MENU>Phone/CW menu, set Iambic Disabled and Swap(DASH/DOT) enabled. This should allow you to use a straight key on the tip of the connector.. I think you will need to NOT use a tip and sleeve connector ( the ring needs to be open circuit).
AL, K0VM
Thank you! It is work!0
