Is it normal to see the 10mhz external reference?
Joe Belden
Is it normal to see the 10mhz external reference I have connected to my 6500 on my pan adapter? My gut says "duh", but I wanted to make sure their isn't some circuitry or software filtering that should be taking it out.
sure .. its strong enough even over interconnections etc to be heard loudly - same here
I concur. The 6000 is very sensitive and if the external unit is leaking the 10 MHz clocking signal, the radio will receive it.0
If I unplug it the signal disappears... perhaps I have it turned up too much. did you guys ever get any kind of indicator to tell us if the radio is using the external reference? How will I know if I've turned it down TOO much?
You should hear a relay click when the 6500 switches from External to Internal ref (at least I do). I can 'hear' my 10Mhz reference as well, I suppose it could be unterminated outputs on my distribution amp?0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
