Maestro won't boot / failed boot - maestrostartup is not responding
Simon Lewis
ran Maestro for 18 hours yesterday not a hiccup after my initial issues on 5g wifi.
today came in - booted the 6500 and then started Maestro
... maestro would not boot ... sat with grey screen and spinning circle of doom
took 3 shutdown and retstarts before it would get into the Maestro boot screen and then again would not find wifi I connected to last night.
finally managed after another reboot it found 2g and i connected to that
and it booted fine
ran for 5 mins then connected to 5g
connected ... eventually .. then errored with a pop up "Maestrostartup not responding" wait/close message from windows.
By the time I got back to Maestro with my camera to take a shot it suddenly and unprovoked .. booted and started SSDR
So something not booting right / failing on boot around wifi
It's also seems very warm round the screen area - upper middle of the screen
- now back to not rebooting
Open a service desk ticket ....
follow on
went to wired lan and made it forget the wifi - instant boot and no errors
def wifi related
and it booted fine
follow on
def wifi related
Hi Simon
The warm area of screen in upper right is something observed here also. I believe it runs cooler / warmer based on LED brightness.
The problem does sound WiFi related. For the 2Ghz band, the auto channel feature failed miserably and I manually set the router for an empty channel.
When switching between direct ethernet Vs. WiFi, it seems the 6500 had to be rebooted to 'reset' the ethernet port due to the cable swap.
Best,
_..--
TiM0 -
Opening a HelpDesk support ticket is the correct course of action.0
I am having similar issues with "Maestro not responding". I submitted a help desk ticket. I just tried connected to Ethernet with the same results. Though WiFi is flaky and I've invested in a new router and wifi extender, the wireless connection causes audio to stop every few minutes (when Mestro is working). I have not tried transmitting with Mestro yet. My Maestro is no longer working as far as I can tell.
Is the Maestro using the extender?0
Yes. Both the radio and Mestro is plugged into a Netgear extender. I just restarted the radio and started the Mestro again and it did boot up this time. No dropped packets. Maybe it is a WiFi problem.1
Depending on the model, some extenders aren't very good at doing their jobs. I've had pretty good luck with Negear. Next time, restart the extender first, see if the Maestro and radio responds better before rebooting either of them.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
