Maestro DEXP Greyed Out
Cal N3CAL
I've noticed DEXP is greyed out / not available on my Maestro for M-MIC1, M-MIC2, M-LINE but available R-MIC, R-BAL and R-ACC?? The manual makes no mention of DEXP not working on the Maestro?? Am I doing something wrong? I'm using a default Radiosport Mic Profile...
Cal/N3CAL
Cal/N3CAL
Cal,
The DEXP function is a hardware function that is availabe in the radio but not available in the Maestro hardware ( or in the PC with a PC mic).
AL, K0VM
Problem is, the mic and/or ambient noise level when you're using the Maestro outside the shack is different. A Heil BM-10 plugged into the RJ-45 on the Maestro pumps room noise like mad with no solution. And that is in my quiet, plaster-walled living room. If I turn compression/mic gain down low enough to solve that I have very little power output. C-1
Bob you are absolutely correct! Another disappointment to me. It will be hard to use the Maestro in a crowded space like a DX expedition or multi op contest! Too much background noise....
Cal/N3CAL
While this is a bummer if you were in a multi op or dx situation you can always plug right into the radio.
Thank you Captain Obvious.
The point here is to use the Maestro REMOTELY, a use that has proven unsatisfactory for this reason.
Almost a year has passed and still the feature is not implemented.
- 384 Community Topics
- 646 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
