Has anyone achieved CW TX (not RX) decoding with a Flex-6xxx?
I started learning CW on a KX3 which has a nice feature of decoding your transmitted CW. The feature is pretty brutal/strict, and has really helped me learn better spacing and rhythm. I’m trying to figure out how to get my Flex-6xxx CW transmissions similarly decoded.
Of course, decoders like CW Skimmer do a pretty darn good job with RX. But, they don’t seem to get the sidetone to decode my TX.
One solution I imagine is to run a hardware lineout of audio from the speaker or headphone port on the Flex into a computer input. With that, at least I would have the sideone in the computer and could (maybe?) run another instance of CW Skimmer (or another decoder) just to decode the transmitted CW.
Am I missing something more obvious to achieve my goal? Other ideas?
Thanks very much.
Mark K9BOO
You could take the audio out (sidetone) into FLDigi or a similar CW decoding app.1
Jerry, AA7SN
DM780 using cw winkey with the winkeyer usb device installed works very well in showing you cw. You can also use it for practice by just tuning off Breakin in the Flex and viewing your keying output in the DM780 window without transmitting a signal via the radio.
Yes, I would also like this ability. It would be a great tool for improving my more transmission (which I suspect is not the best). Good luck in your quest.0
Mark,
see hier:
http://df4kv.darc.de/computer.html
The best one !
We work on Windows version with androino uno. You can keying you radio and see, what you send:)
cheers
Emil, de DL8JJ
- 246 Community Topics
- 489 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
