SO2RDefault default profile
Ray G6UJB
The loading of SO2RDefault profile on a 6500 following a factory reset loads two panadapters, one with a slice receiver on 20M(14.100) and the other with a slice on 40M(7.100) but both have modes set to DIGU with a slice bandwidth of 0 - 200Hz which is not a normally selectable bandwidth for DIGU and the mouse click tuning is totally off with this odd bandwidth ?
Just seems a weird default?
Do others see this?
Ray G6UJB
Do others see this?
Ray G6UJB
Ray as far as I know these were starter profiles set up to implement a basic starting point for settings, then you can save off your specific ones. I agree that the raw defaults are a bit weird. I will test this out and if needed bring it up on the alpha list as we move back into an SSDR development cycle and see if we can hone one or two default profiles to make a bit more sense. As it stands it is a bit rough around the edges.
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
