SO2RDefault default profile
Ray G6UJB
Ray G6UJB Member ✭✭
edited April 2017 in SmartSDR for Windows
The loading of SO2RDefault profile on a 6500 following a factory reset loads two panadapters, one with a slice receiver on 20M(14.100) and the other with a slice on 40M(7.100) but both have modes set to DIGU with a slice bandwidth of 0 - 200Hz which is not a normally selectable bandwidth for DIGU and the mouse click tuning is totally off with this odd bandwidth ?
Just seems a weird default?
Do others see this?
Ray G6UJB
  • ctate243
    ctate243 Member ✭✭
    edited April 2017
    Ray as far as I know  these were starter profiles set up to implement a basic starting point for settings, then you can save off your specific ones.  I agree that the raw defaults are a bit weird.  I will test this out and if needed bring it up on the alpha list as we move back into an SSDR development cycle and see if we can hone one or two default profiles to make a bit more sense.  As it stands it is a bit rough around the edges.
