Maestro Configuration Menu - Add to each a "One to the Next Sequencing Button?"
Perhaps I've missed a configuration menu to next configuration menu shortcut, as it would seem useful to have a way that once any configuration menu is open the Maestro user would be able to sequence through the other configuration menus without returning to the main screen.
So if I started by pushing the knob for say the Transmit Menu that every time I pushed say the sub VFO knob briefly that I would move to each other Configuration Menu in a circular sequence.
If I started by pushing the Menu touch-screen graphic for Menu, I would start the rotation at that point, but again be able to cycle through without closing configuration menus.
Hope this is making sense, as basically I would like to suggest an easier way to check every configuration from one place.
Could that work?
Steve K9ZW
Adding an observation and an additional suggestion.
In most cases the present menus have the value in use highlighted, but not in all instances. It would be helpful to have the previously selected values always highlighted.
As an additional suggestion - would it be possible to use some color in the menus, and avoid the dull grey low contrast presentation. Colors could be used very effectively to bring the same high level experience to the menus as the main operating screens.
Steve K9ZW
2
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
