Audio Switching and multiple DAX devices
I found this program that allows me to easily switch audio devices and also clear up the multiple DAX devices listed in sound control panel when they display on this interface (note they still exist in the windows sound panel but you no longer need to go there to switch devices). I have tested this on Windows 7 and Windows 10. I have it load when Windows starts up. WIth the tray icon it is now a two click operation to change from one audio device to another.
I am not associated with this program in anyway and just suggesting it for anyone that does audio switching from headset to local speakers that has gotten tired of having to scroll thru the multiple DAX devices to find the correct device each time you want to make a switch.
https://github.com/sirWest/AudioSwitch/releases
John K3MA
John K3MA
Thanks for posting this John.
I tried this software and the thing I see is the reserved DAX channels. RT clicked and tried the settings but still get same results. Needs work.0
Bob follow these instructions. Right click icon in task bar and bring up settings. Click on second tab tittled "Devices". On the left side of the window click on the device you want to remove from the view. In our case one of the DAX devices. One the right side of the view put check mark in box labelled "Hide device from switch list" Click button "Save Settings". When you do the Save the device text will change to slanted text font. Move to next device in the list you want to hide and repeat. Repeat again and again until all DAX devices are changed. Click on "Close". Now when you left click on the program in the task area to change the Audio device you will see the list does not have the DAX devices any longer.
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
