Maestro and Access Point
http://www.practicallynetworked.com/networking/convert_wifi_router_to_access_point.htm
I'm am a little network challenged but even I was am to accomplish this. My Router is located about 75 to 100 feet from my ham shack. I have Cat 5e to the ham shack but I wanted the flexibility of a WIFI connection to my Maestro. The Maestro connection on either 2.4 or 5 ghz was NOT reliable to the main Router.
I took an old wireless g router, disabled DHCP and changed the LAN IP to 192.168.1.2. I also set the WIFI channel to channel 11. I connected one of the ethernet inputs from the old router to the Cat 5e run from the main router. No connection was made to the old WAN input.
This may be old hat to the network gurus but was new to me.
The Maestro works perfectly with zero dropouts.
Mark NU6X Sedona, AZ
Another method is to use an AV Ethernet adapter connected to the 120 V AC power line. This unit transports Ethernet to a remotely located AC outlet. Connect another AV unit to the outlet and you will have an access port available on the AV Ethernet output. From this you can connect a another wireless router This antic takes the place of a very long CAT-5 cable.
Jim, K6QE
Really bad idea... I found that using 120VAC lines as substitutes for Ethernet cables generated all sorts of unwanted noise and birdies in the HF bands... plus you are creating an unshielded ingress for RF from your transmitter to your network...
Howard/Jim I know that Ethernet over power line has a bad reputation but I have had excellent results using this Ethernet extension application. Runs about 30Mb (speedtest) and feeds an Apple Express in another part of home as subnet. Your mileage may vary. Would that wall warts were as clean. Bob W5TX0
I bought a pair of those AC line Ethernet extenders and took them back to the store after finding the 30 meter band useless due to the interference. Different versions would probably effect different bands.0
I had Ethernet over power line in our place in the South of France.. I was a totally RF Noise nightmare... Spurs all over the HF bands...So bad that I gave up using the IC-706 I had schelped with me from the USA.that I had planned to leave there permanently. It was a major incentive to start using Remote iPad to Flex...0
Some of the adapters are better than others, I have seen some with 0 hf issues and some with big ones. This is another spot where length of wires comes into it.0
Purchasing a commercial quality access point will solve many WiFi issues seen with the less expensive home quality equipment. The network infrastructure in your QTH is the foundation for network connected radios like the Flex. The difference in performance between a home quality WiFi router and a commercial quality access point is substantial.
Also some confusion about access point VS range extender they are not the same.
Access point is one ended only and ranger extender is a repeater which extender will add latency.
Similar Idea ,,https://community.flexradio.com/flexradio/topics/outdoor-wireless-access-point
And half your throughput too0
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
