Maestro monitor function doesn't work with the Maestro mounted FHM-1
I want to set equalization for the FHM-1 using the monitor function, but it doesn't appear to work with the Maestro connected mic. I can hear myself clearly with the 6700 connected PR-781, but not with the FHM-1. My local net buddies give me terrible audio reports with the FHM-1. I have tried the stock FHM-1 profile, but apparently I still sounded cruddy to them.
Any thoughts?
Thanks -- Keith - AC9S
Any thoughts?
Using the Monitor function won't help you adjust your TX equalization. Per the manual:
"monitor audio bypasses the signal processing stages, the audio heard in the monitor is not the same as what is being transmitted and therefore is not suitable for determining the over the air quality of your transmitted signal".
If you want to hear what you sound like and adjust your equalization use Full Duplex (FDX) using two slices tuned to the same freq. Listen with headphones on the receive slice and adjust as you desire.
Cal/N3CAL
OK - but that doesn't explain why Monitor doesn't work with Maestro connected microphones.
Keith - AC9S0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
