maestro locked up in Xmit is there a master reset
Verne Eastwood K4VAE
Received and was loving the Maestro. After about 28 hrs of running my 6700 the maestro went into Transmit and locked up. I did not key the unit and had to manually shut everything down. Now when I power up the Maestro it is locked in Transmit with the MOX button glowing red. Maestro is not responsive to any control function including the on off switch. The 6700 works fine when connected to PC and SSDR 1.7.30.
Am I missing something?
Verne, press and hold the power button until the bottom Half of the screen turns blue. Then swipe down. That causes a hard reboot of the maestro. Let me know if that works. Mack W4AX Alpha team0
Thanks Mack,
No that does not work. I hold the power button down and have black screen, the small white timer spinning then unit shuts off while still holding the power button.
Verne
K4VAE
Verne,
Do this. Disconnect all cables except DC power (don't run off the battery)
Press and hold the power button on top for a full 15 seconds. This will do a forced powerdown as opposed to the forced shut down recommended by Mack.
Let me know if this worked or not.0 -
Verne,
Try this. Start SmartSDR, back up your profiles, shut down SmartSDR, Factory reset the radio (press the round button in the middle of the four arrows, press and release the power button, when you see resetting to factory defaults release the round button). Try with your Maestro now.
Mack
W4AX0 -
Ok Gentlemen;
Thank you Mack and Thank you Tim.
Tim I read your post first. This seems to have gotten things back to where they should be. I will set up and start playing again later tonight and hopefully no problems. For the record I was on AC power but had the Polanfo battery pack installed. Battery was at full charge when installed and I had not run the Maestro off the battery pack.
Thanks for the help and extremely fast response.
Verne
K4VAE0 -
I have a question. Were you actually transmitting when the Maestro locked up? I could not tell for certain from your description.0
No Tim I was not transmitting and in fact there was nothing hooked up to the Maestro. No mike, no PTT switch, no key. Unit was sitting on livingroom table just receiving while I did my best plumber routine in the laundry room. Yes, I got a Maestro. The wife has a new washer and dryer. Even trade I would say!
Verne
K4VAE1 -
Interesting. Obviously, it should not crash like that spontaneously. If this happens again, please open a HelpDesk ticket so that we can investigate in more detail. I may miss a Community post, especially with Dayton next week.0
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 329 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 770 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
