The SmartSDR_v1.7.30 does not save my waterfall settings, will this be corrected? Is there a differ
Phil
Member ✭
SmartSDR_v1.7.30 does not save the waterfall settings on my 6700. The previous versions have. Will this be corrected? I miss not having it already setup.
Which settings?0
Black level for one....0
I have seen this before and if I remember correctly resetting the radio to factory defaults resolved the problem.0
Is Auto Black on or off?
This is the same as :
https://community.flexradio.com/flexradio/topics/smartsdr-1-7-30-78-waterfall-sometimes-stays-white-...
73 de Mike W9OJ0 -
Tim, with Auto Black Off and even factory reset and saving a new profile when you recall the profile the Black Level always goes back to 33 regardless. I am having the same issue.1
Thanks for the info. I have entered this as defect #3621 for further investigation.1
I think I am having the same issue. My waterfall is basically yellow each time I start. I need to back the black slider down to even see activity.
So for now Ia m going to revert to the older version until its resolved. 6500 in my case.
It's been several weeks since this happenned to me and since I solved the problem by doing a power off, disconnect power, reconnect power then power up to factory defaults I never mentioned it to the Alpha group. The display options AVG and Black (Auto off) were set to 0, sliders all the way to the left. I also believe the Gain was set higher than I like. Maestro reset did not affect it. It was reasonably annoying. None of the other Alphas were reporting it so I thought I missed something by not resetting the radio. This happenned over two revs of the software. The issue has not happenned to me over the last 3-4 revs. Flex 6700... In the future I'll just embarrass myself more than usual and report everything.
WB8CXO0 -
I just found this thread after I posted an inquiry about the same problem I have noticed regarding the Black level not being saved and always reverting to 33. I have this will be solved soon. It is annoying!0
This is a defect that will be addressed in the next release of SmartSDR for Windows.
- 382 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 434 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 933 Genius Products
- 341 Tuner Genius XL
- 303 Shack Infrastructure
- 141 Amateur Radio Interests
