The SmartSDR_v1.7.30 does not save my waterfall settings, will this be corrected? Is there a differ
Phil
Phil Member
edited March 2019 in FLEX-6000 Signature Series
SmartSDR_v1.7.30 does not save the waterfall settings on my 6700. The previous versions have. Will this be corrected? I miss not having it already setup.
    edited March 2017
    Which settings?
  • k0eoo
    k0eoo Member ✭✭✭
    edited March 2019
    Black level for one....
  • Mike_WB8CXO
    Mike_WB8CXO Member ✭✭
    edited May 2016
    I have seen this before and if I remember correctly resetting the radio to factory defaults resolved the problem.
    edited December 2016
     Is Auto Black on or off?
  • Mike W9OJ
    Mike W9OJ Member ✭✭
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited November 2016
    Tim, with Auto Black Off and even factory reset and saving a new profile when you recall the profile the Black Level always goes back to 33 regardless. I am having the same issue.
    edited March 2017
    Thanks for the info.  I have entered this as defect #3621 for further investigation.
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    edited May 2016
    I think I am having the same issue. My waterfall is basically yellow each time I start. I need to back the black slider down to even see activity.
    So for now Ia m going to revert to the older version until its resolved.  6500 in my case.
  • Mike_WB8CXO
    edited May 2016
    It's been several weeks since this happenned to me and since I solved the problem by doing a power off, disconnect power, reconnect power then power up to factory defaults I never mentioned it to the Alpha group.  The display options AVG and Black (Auto off) were set to 0, sliders all the way to the left.  I also believe the Gain was set higher than I like.  Maestro reset did not affect it.  It was reasonably annoying.  None of the other Alphas were reporting it so I thought I missed something by not resetting the radio.  This happenned over two revs of the software.  The issue has not happenned to me over the last 3-4 revs.  Flex 6700... In the future I'll just embarrass myself more than usual and report everything. :)
    WB8CXO
  • Arnie
    Arnie Member ✭✭
    I just found this thread after I posted an inquiry about the same problem I have noticed regarding the Black level not being saved and always reverting to 33. I have this will be solved soon. It is annoying!
    This is a defect that will be addressed in the next release of SmartSDR for Windows.
