New DAX issue with this recent update.
Howard Koenig
Since updating to 1.7.30.160. DAX streams until I close digital program (psk, jt, etc). Then it no longer works. Says it is streaming but no audio coming through transmit and receive. Tried shutting radio and turning back on. Tried rebooting the computer. The only way to solve this is to do a hard reboot of the box. Never had this problem with last version of software. I've repeated this several times over the weekend. Is there a way to do a hard reboot without having to be at the box and holding the button? Would be nice to be able to remotely reboot the 6300. But why should this have to be done?
Howard, I'm using Windows 7/64 along with WinWarbler version 8.6.4 and as far as I can tell I don't have any problems. I switched between modes and also closed and reopened WinWarbler a number of times and all appears to be works as it should.
I'm using a Flex-6500, but don't think that should change things.
So far I have had zero issues with update to new version.
Lew N4CO0 -
Also using Win 7
Howard - please cold boot the radio to ensure that all of the processors rebooted after the update. To do this, power down the radio normally, remove DC power for about 15-30 seconds, reconnect DC power and power up the radio using the front panel power button. Let me know if this helped.0
Just happened again after several hours working.. Just stops.0
Did you cold boot the radio as I suggested?0
yes.. I did0
Thanks for the confirmation.
Question. I am a little unsure about your problem description. When you say "The only way to solve this is to do a hard reboot of the box." please describe what you are doing since in the sentence before you say "Tried shutting radio and turning back on."
Does this mean the radio will not shut down with a momentary press of the power button?0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 720 Genius Products
- 387 Power Genius XL Amplifier
- 249 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
