New DAX issue with this recent update.
Howard Koenig
Howard Koenig Member
edited January 2018 in FLEX-6000 Signature Series
Since updating to 1.7.30.160.  DAX streams until  I close digital program (psk, jt, etc). Then it no longer works. Says it is streaming but no audio coming through transmit and receive. Tried shutting radio and turning back on. Tried rebooting the computer. The only way to solve this is to do a hard reboot of the box. Never had this problem with last version of software.  I've repeated this several times over the weekend. Is there a way to do a hard reboot without having to be at the box and holding the button? Would be nice to be able to remotely reboot the 6300.  But why should this have to be done?
  • Lewis Cheek
    Lewis Cheek Member ✭✭
    edited January 2018
    Howard, I'm using Windows 7/64 along with WinWarbler version 8.6.4 and as far as I can tell I don't have any problems. I switched between modes and also closed and reopened WinWarbler a number of times and all appears to be works as it should.
    I'm using a Flex-6500, but don't think that should change things.
    So far I have had zero issues with update to new version.
    Lew N4CO
  • Howard Koenig
    edited May 2016
    Also using Win 7
  • Tim - W4TME
    edited March 2017
    Howard - please cold boot the radio to ensure that all of the processors rebooted after the update.  To do this, power down the radio normally, remove DC power for about 15-30 seconds, reconnect DC power and power up the radio using the front panel power button.  Let me know if this  helped.
  • Howard Koenig
    edited March 2017
    Just happened again after several hours working.. Just stops.
  • Tim - W4TME
    edited December 2016
    Did you cold boot the radio as I suggested?
  • Howard Koenig
    edited May 2016
    yes.. I did
  • Tim - W4TME
    Thanks for the confirmation.
    Question.  I am a little unsure about your problem description.  When you say "The only way to solve this is to do a hard reboot of the box." please describe what you are doing since in the sentence before you say "Tried shutting radio and turning back on."
    Does this mean the radio will not shut down with a momentary press of the power button?
