PW-1 amp and Flex and software
Michael Coslo
My club has recently bought a used PW-1 amp. I get to make it work. Since it will be used for contesting and Field day, I had to get the Store and forward board so that it doesn't puke (technical term) if it gets a bad instruction from the software to make a long story as short as practical, if the amp doesn't hear from the radio for around 10 seconds, it asserts itseld as the master of the data bus, then expects na instruction from the radio. But it is possible that the computer and software might send out some data that the PW-1 interprets as bandswiting, and when you transmit - kablooey.
So the amp works FB now with an IC-756 Pro 3 and Store and hold hardware, but my cohort in organizing field day would really like me to connect my Flex 6300 to the amp for field day. I kinda wouldn't mind this myself, as it is so much better than the 756 pro 3.
So DDutil apparently functions to connect a PW-1 to a Flex Radio - although the authors Wiki I looked at reads about the Flex5000, and the radio control programs part could be a little more specific.
So my question after all that, is has anyone interfaced their signature series radio to a PW-1 amp and used N1MM contest logger with the setup?
In addition, is the Store and forward device still needed? I suspect it couldn't hurt, but if anyone has a definitive answer it would be greatly appreciated.
I'm planning on using the same amp, so I am interested in the answer!
After several days of trying different interfaces we were able to get a 6700 working with a PW1 by using the Icom CT17 and DDUtil. When setting it up it was important to move the VFO very slowly when trying to get the frequency to link between the rig and the amp. Moving to quickly would not establish a link. I have not tried to also get N1MM to work with it.
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 259 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 905 Maestro
- 50 FlexControl
- 863 Genius Products
- 305 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 714 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 936 Third-Party Software
