PW-1 amp and Flex and software
Michael Coslo
My club has recently bought a used PW-1 amp. I get to make it work. Since it will be used for contesting and Field day, I had to get the Store and forward board so that it doesn't puke (technical term) if it gets a bad instruction from the software to make a long story as short as practical, if the amp doesn't hear from the radio for around 10 seconds, it asserts itseld as the master of the data bus, then expects na instruction from the radio. But it is possible that the computer and software might send out some data that the PW-1 interprets as bandswiting, and when you transmit - kablooey.
So the amp works FB now with an IC-756 Pro 3 and Store and hold hardware, but my cohort in organizing field day would really like me to connect my Flex 6300 to the amp for field day. I kinda wouldn't mind this myself, as it is so much better than the 756 pro 3.
So DDutil apparently functions to connect a PW-1 to a Flex Radio - although the authors Wiki I looked at reads about the Flex5000, and the radio control programs part could be a little more specific.
So my question after all that, is has anyone interfaced their signature series radio to a PW-1 amp and used N1MM contest logger with the setup?
In addition, is the Store and forward device still needed? I suspect it couldn't hurt, but if anyone has a definitive answer it would be greatly appreciated.
I'm planning on using the same amp, so I am interested in the answer!
After several days of trying different interfaces we were able to get a 6700 working with a PW1 by using the Icom CT17 and DDUtil. When setting it up it was important to move the VFO very slowly when trying to get the frequency to link between the rig and the amp. Moving to quickly would not establish a link. I have not tried to also get N1MM to work with it.
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
