rf power spec
New Flex-6500 on order to replace (upgrade) Flex-5000A. The Flex-5000A is 100 watts continuous which is great as a remoteham station.
RF Output Power: 1-100W nominal SSB, CW, FM, RTTY, Digital; 1-25W nominal AM
http://www.flexradio.com/amateur-products/flex-6000-signature-series/flex-6500/
Hi Ron
Congrats on the update. I kept my 5000A for a while until passing it on.
The 6000 series are also 100w (excepting 4m (6500) and 4m/2m (6700) which have their output power defined by the transverter setup). Same robust output.
http://www.flexradio.com/amateur-products/flex-6000-signature-series/comparison-table/ is a nice handy chart summarizing features.
Hope you have as much fun with your new Radio as the 5000A. I did want to write this comment as I did not fully accommodate how legacy my shack's legacy PC was, and though it ran SmartSDR (Preview at the time) "okay-ish" it wasn't until I replaced with with one of Neal's FlexReady computers that I was happy. Just mentioning it in as there is no need for others to repeat the mistake I made that my old XP box was going to serve well just because it had a onetime great processor.
The SmartSDR page has a Requirements Tab that both lists and also links a lot of information on the PC issue: http://www.flexradio.com/amateur-products/flex-6000-signature-series/smartsdr/
All best, good luck and 73
Steve K9ZW
This question, while simple in nature has a very complex answer. There are multiple variables in play such as PA design, ambient temperature and the quality of air flow around the radio.
From the design standpoint, the PA in the FLEX-6000 is designed and rated for nominal 100W ICAS (Intermittent Commercial and Amateur Service) output. ICAS implies that the transmitter is not designed to be turned on, operated at max power and left on indefinitely (that is CSS - continuous commercial service). Under the ICAS classification for solid-state amplifiers, it implies de-rating to keep the device junction and case temperatures within their maximum ratings. Thus, ICAS suggests a limited operating or 'on' period followed by an 'off' or standby period of at least the same or longer duration.
The PA transistors in the FLEX-6000 are stout and well de-rated so that you should not expect any issue operating full duty cycle modes. And there is also thermal protection built in that will shut down the radio before any damage can be done, which is really the most critical aspect of this question.5 -
TNXs Tim,
That was the answer I was looking for. Looking forward to my new Flex-6500. The Flex-5000A was a great and real work horse of a radio.0 -
Which model of final transistor does a Flex 6000 use anyhow?
Mitsubishi RD100HHF1
Yeah you can't hurt it.
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
