I just brought the Flex-6300 , I would like to run it on it on my Ameritron AS 572 tube amp need hel
Hugo Escalante
It is the same as most amplifiers. You need at least one RCA cable for PTT. It goes from the keying line on the AMP to the TX line on the 6300.
If you use ALC, then you'll need a second cable RCA cable.
Other than the obvious jumper RF Jumper cable, you are ready to go.
Mike va3mw
Just confirm the switching voltage and current are within the range the Flex can handle. You may need a small interface relay box.0
Ameritron keying lines are 12V @ 100ma, well within Flex's relay limits.
file:///C:/Users/840G1/Downloads/AL-572.pdf
George,
I use an AL-572 with my 6700. The switching requirements are definitely within the safe limits for direct keying.
73, Ray, K9DUR
George,
Can you tell me what cables you using and connecting them?
Hugo0 -
Mike,
Not sure what jumper cables you talking about, can you share.
Hugo0 -
The cables you need are:
1. Coax jumper between radio and amplifier.
2. Cable with male RCA phono plug on each end between the TX1 jack on rear panel of radio to the RLY jack on the rear of the amplifier. Be certain to enable RCA TX1 in the transmit settings form in SmartSDR.
3. (Optional) Cable with male RCA phono plug on each end between the ALC jack on rear panel of radio to the ALC jack on the rear of the amplifier. This cable is needed only if you wish to use ALC. I do not.
73, Ray, K9DUR
Ray0
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
