I just brought the Flex-6300 , I would like to run it on it on my Ameritron AS 572 tube amp need hel
Hugo Escalante
Hugo Escalante Member ✭✭
edited February 2019 in FLEX-6000 Signature Series
  • Mike va3mw
    Mike va3mw Member ✭✭
    edited February 2018
    It is the same as most amplifiers.  You need at least one RCA cable for PTT.  It goes from the keying line on the AMP to the TX line on the 6300.
    If you use ALC, then you'll need a second cable RCA cable.
    Other than the obvious jumper RF Jumper cable, you are ready to go.
    Mike va3mw
  • George KF2T
    George KF2T Member ✭✭✭
    Just confirm the switching voltage and current are within the range the Flex can handle. You may need a small interface relay box.
  • Mike va3mw
    Ameritron keying lines are 12V @ 100ma, well within Flex's relay limits.
    file:///C:/Users/840G1/Downloads/AL-572.pdf
  • Mike va3mw
  • K9DUR
    K9DUR Member ✭✭
    edited September 2016
    George,
    I use an AL-572 with my 6700.  The switching requirements are definitely within the safe limits for direct keying.
    73, Ray, K9DUR
  • Hugo Escalante
    edited May 2016
    George,
    Can you tell me what cables you using and connecting them?
    Hugo
  • Hugo Escalante
    edited May 2016
    Mike,
    Not sure what jumper cables you talking about, can you share.
    Hugo
  • K9DUR
    K9DUR Member ✭✭
    The cables you need are:
    1.  Coax jumper between radio and amplifier.
    2.  Cable with male RCA phono plug on each end between the TX1 jack on rear panel of radio to the RLY jack on the rear of the amplifier.  Be certain to enable RCA TX1 in the transmit settings form in SmartSDR.
    3. (Optional)  Cable with male RCA phono plug on each end between the ALC jack on rear panel of radio to the ALC jack on the rear of the amplifier.  This cable is needed only if you wish to use ALC.  I do not.
    73, Ray, K9DUR
  • Hugo Escalante
    edited May 2016
    Ray
