Yaesu MH-31A8J Mic
Bob G   W1GLV
Bob G W1GLV Member ✭✭
edited June 2020 in Maestro
I assume this mic will work with the MAESTRO. I hate to make assumptions. I was looking at the connection schematic, it shows a fast, up, down switches, I assume those are not connected in the MAESTRO.
  • N4TTY
    N4TTY Member ✭✭
    edited May 2016
    According to the Maestro User Guide:
    Steve G./N4TTY
  • Bob G   W1GLV
    edited June 2020
    Steve I looked at that illustration in the Maestro manual. If you go and check the Yaesu site for the connections on the MH-31A8J you will find some that don't match. If the up,down & fast are not used on the Flex Maestro circuit board, then everything is good. Thanks for the reply.
  • Tim - W4TME
    edited June 2020
    It should work.
  • Bob G   W1GLV
    edited December 2016
    Thanks Tim.
  • Warren Wegerer
    Warren Wegerer Member ✭✭
    edited May 2018
    Bob, I'm wondering what you found with your MH-31 experiment? I know the wiring should work , but the MH-31 is a dynamic mic and I believe the Flex mics are condenser type. I'm guessing if it worked you  deselected Bias, and perhaps used the +20dB boost. What was your result with the MH-31 and what settings do/did you use if it was successful?
  • Alex B
    Alex B Member
    edited September 2019
    I tested the MH-31 mic over the last weekend with my FLEX 6300 and was pleasantly surprised, good audio reports. The mic is connected to my Maestro. Yes the 3 buttons do not work but as a temporary substitute until the original FLEX mic is acquired in due course, this serves as a good replacement and works. This mic is originally from my Yaesu 897D.
  • ik3ghr Fortunato
    ik3ghr Fortunato Member ✭✭
  • ik3ghr Fortunato
