SSDR Serial Number filter (filter.txt) file issue in Windows 10
Greg - K5GJ
SUMMARY:
In Windows 10 with DEFAULT File Management settings, Creating a NEW text file will automatically append the '.txt' to the filename. If creating a new filter.txt file for limiting SmartSDR access to certain radios, just use the name 'filter'. Otherwise you end up with 'filter.txt.txt' .
GORY DETAILS:
Ran into an interesting Windows 10 issue with the filter.txt file used to point a PC at a Specific FLEX-6000 Series serial number:
After navigating to the %appdata%FlexRadio Systems directory, I used the right-click/NEW/Text_Document shortcut to create a new filter.txt file. You can now see the name "filter.txt" in the directory.
Once done, I then opened the file and added the appropriate Serial number and was sure to hit SAVE then close the file.
I then started SmartSDR expecting to only see the 'filtered' radio... Alas, both radios on the network showed up.
After pulling what remaining hair I have, I got with Tim and we both discovered that Windows 10, being the always _helpful_ software, just ASSUMED my newly created text file needed a '.txt' appended to the name. This created 'filter.txt.txt'. SmartSDR is not looking for that file.....
It was a simple fix to rename the file 'filter' and let Windows 10 append the '.txt' to the name. Mischief Managed.
Greg - K5GJ
GORY DETAILS:
Greg - K5GJ
Greg, As a former "Softie" I just have to speak up and say that Windows 8 and 8.1 were just as "helpful" :-)
Windows Explorer. View-> File Name Extensions. Done.0
Agreed. Hence the note: "..with DEFAULT File Management Settings..." In this case I was working remotely on someone else's computers who had just done fresh installs of Win10. Most of us 'ancients' are used to seeing extensions but it looks like they are getting pushed farther into the background.
Thanks for the additional tip for the ops out in radioland.
73,Greg
I've installed Windows 98, XP, 7, 8.x and 10 now so many times that my fingers are numb. And every time I do this setting is one of the first things I turn off (or on depending). In Windows 7 you had to go to the Explorer Folder View settings and turn OFF "Hide extensions of known file types" and now in Windows 10 you have to turn ON that checkbox. MS is always trying to force us to use the OS the way THEY think we should, and not how we actually do.
I tend to save these kinds of things in registry update files. Another one for Windows 10 that drives me nuts is that it keeps trying to take over default programs even after I've installed for example Notepad++. I don't want Windows changing the default app to Notepad ever again, but it does. Here is the solution I use http://winaero.com/blog/prevent-windows-10-from-resetting-your-default-apps/
Danny0 -
@Danny & Greg, thanks for the tips. Very useful information.0
I NEVER use the "DEFAULT" settings for much of anything in Windows. In fact, during the 15 years I ran my own computer consulting and repair business, whenever I setup a new Windows machine, I had a list of many changes to make (including several registry tweaks) that I performed before releasing any machine to an end user. In fact, many of the complaints about Windows 10 "phoning home" to Microsoft are easily resolved with various reconfigurations, such as not utilizing an MS "Live" account (especially for login), or enabling Cortana or any of the newer Windows "features." I find that reconfiguring a Windows 10 machine to make it more like Windows 7 leads to simpler and more reliable operation. 73, Greg - N8GD0
Classic Shell is your friend.0
I agree. It makes Windows 10 easier to use!
Greg - N8GD0
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
