Gentelmen, anyone knows if DM780 bug is fixed?
YV5WZ
I'm talking about impossibility of doing transmission from DM780 on Windows 10
DM780 does everything inclusive I can see transmission on DAX channel box....but doesn't key flex.....I have read its some kind of virtual port incompatibility
Has Anyone hear somthing about?
As I recall it works fine here. I thought I had an issue with rtty some time back, a month or so ago. I've forgotten who it was that showed me but it worked fine. Are you using the subscription DM 780 or the free one?0
Hey Walt...I have subscription....I already did Update....but ....It doesn't solve key problem0
Would you elaborate? Is this in general, only on transmission, only on psk or rtty or some other mode?0
What did you mean by update? Sound card definitions?0
I mean my HRD is updated to last version ...transmission are affected in all modes
Its connected, I can change frequency, mode, and everything from DM780.....I have created 2 news CAT ...and tested with Fldigit and WSJT-x with No problem.....0
I am at 6.3.0.466 and it works fine.
do you have HRD with DDutil....? and work ok?0
In the top right I have a digital clock, not a freq but I sent QRZ and the read led on the radio lit, and I can copy a boatload of psk at 14.070...with ddutil0
It (ddutil had downloaded the most recent copy as well.
Are you running the same version of ddutil?
Look at SmartSDR Cat and see if the P (ptt) port is assigned to Digital Master.
And that it says "Radio Connected".0 -
SRY, meant the same version of dm780.
Using latest release of HRD and have had no problems keying, Program Options, PTT I am not using the HRD option but using the COM Port with the port I assigned to the slice A in SmartSDR CAT.
If you are running DM780 standalone, you will need to use a PTT com port to key the radio, if running with HRD, make sure your IPServer is running and you are seeing the frequency of the radio being passed to DM780, or CAT data from HRD's IPServer .. There never has been a compatibility issue with DM780, only setup issues..
Dudley
Hello Dudley ...I created a CAT for DM780 standalone.....I uninstall HRD and reinstalled fresh.....Before I could see frequency.. now....I just see Radio word .....And I still see transmission on DAX box....but....nothing happens in Smart SDR0
Walt, I have last DDutil version as well as same DM780 version you have, I dont recall if i did any change about clock...but it show radio frequency....I uninstalled and reinstalled HRD ....but still I cant get it to transmit 0
I think I got some CAT trouble....but I cant define whats the problem0
Solved!!! After reading Manuals ( HAM don't read Manual)......I had created CAT and not PTT, the problem was that... I created 3 CAT port.....but I needed PTT port....in smartCat old version.....was just click....but in this new version (excellent by the way) ..its necessary pull down menu and doing the right selection... Thanks to Walt KZ1F who helped me to calm down....to Dudley WA5QPZ who cleared my mind when said: " There never has been a compatibility issue with DM780, only setup issues" and to Mike VE3CKO who wrote "PTT"
You made my day guys....thank you
Hope to find you on bands
George
YV5WZ0 -
Ham operators read only marginally more than software people. I'm glad it's solved.1
Glad you got it solved. DM780 works fine, and the integration with HRD Log & Rotor is the best part of it. I've confirmed 115 countries on RTTY in 2 years with DM780.1
Really Rick? That's awesome! I think my confirmed rtty count is 15 or thereabouts.0
Wow!! Rick 115 its more than a half of world...Congratulations!!!0
- 322 Community Topics
- 588 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 391 SmartSDR for Mac
- 257 SmartSDR for iOS
- 245 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 12 Aurora
- 146 FLEX-8000 Signature Series
- 903 Maestro
- 50 FlexControl
- 861 Genius Products
- 443 Power Genius XL Amplifier
- 304 Tuner Genius XL
- 114 Antenna Genius
- 272 Shack Infrastructure
- 192 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 710 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 935 Third-Party Software
