Need instructions to do a complete uninstall SmartSDR from WIN 10 short of reformatting HDD
Tim, our resident and munificent genius has written comprehensive instructions on the uninstall. Just Google for the instructions. Also, but this is not official, I have had success in uninstalling SmartSDR using a third party program called Revo Uninstall Pro. When you invoke this program, it not only does a "regular" uninstall but also scans for vestiges of Flex programs on the computer and eliminates them if you opt to do so.
Jim, K6QE
I Googled it for youi....
Thanks Jim - Roger on Tim's procedures. I did do Tim's procedure on a WIN 8.1 and that worked great. So I assume that Tim's procedures are universal and covers WIN 10?????
OK on Revo - I may have used that in the past but if Tim's procedures work specifically for SmartSDR that wud be better?
No need to use Revo if you follow Tim's instructions
Thanks 4 link. His procedure is assuming that u have not installed WIN 10 yet - however I wud assume that if procedures were different uninstalling SmartSDR from WIN 10 he wud have said. Hopefully. Microsoft forced WIN 10 install without permission so I was caught!
Roger - Thanks Ross... Will probably proceed with Tim's instructions on WIN 10. Looks like safe procedure per u all. Fingers crossed.
In any event, Revo is a nice program to have on hand as many programs leave unnecessary stuff hanging around and it's nice to get rid of it. Good luck on your uninstall.
Jim, K6QE
Jim, K6QE
There is a lot of that going around. I have a win7 machine on an mid 2011 i5 iMac, running in bootcamp. Even though the machine doesn't run bootcamp that supports W10, it keeps trying to sneak in on me. So as soon as it happens, I am SOL. The latest trick is a blank window, that when you click to try to get rid of it, gives you the prize. I'm waiting for the install to happen as soon as I boot one of these days.
The fun part is that there are people who swear on a stack of Clark bars that Microsoft does not do this. They do, and it is a criminal act.0 -
+1 for Revo Pro. Tim's method works, but there are more steps that could be missed and Revo is even more thorough. Plus, it's useful for cleaning up junk software that may be littering your HD.0
Thanks 4 info. What if I do Tim's method that is specific to SmartSDR and if no workee - run Revo Pro? to clean up any remaining bits? Assume that Revo and SmartSDR r written to certain software specs to b smart enuf to identify 100% of SmartSDR pieces / Drivers / Services / etc... to delete.... ????
-1 for using anything to do the uninstall other than the (automatic or manual) uninstall procedure provided by the software developers. This goes *double* for anything that includes one or more drivers.
Many of the standard Windows Registry entries for system software programs like drivers are undocumented, internal use only, and subject to change. Uninstallers frequently make assumptions about these entries and how they're used. When the uninstallers work, they can make for a slick and comprehensive uninstall. But you're playing dice with your Registry. Works today... but does it work after the next service pack? Does it work under all conditions?
Just the opinion of one humble software developer who hates to see unsuspecting users get themselves in trouble,
Peter
K1PGV
Tnx Peter, Well said! Very good advice! If I read u correctly - Tim's method shud be best since it is based on specific software SmartSDR etc. Drivers ... Tim's method worked perfectly on my WIN 8.1 OS for upgrading SmartSDR - no glitches!
Hope that it works as well on WIN 10 with older SmartSDR. Will let u know. I thot I wud ck 2 c if the existing old version SmartSDR in WIN 10 was working and got error indication that I needed to back step software to make it work WEIRD! I am going straight to uninstall soon. When WIN 10 was forced install (NO PERMISSION) on my system - that caused major problems! Tnx agn 4 advice.....
I also was caught with a unsolicited win 10 upgrade. Pretty much followed Tim's procedure but did not uninstall Flex control or VSP. I answered NO to retaining DAX. I took off every other SSDR related item in control panel and rebooted, then installed a fresh 1.6.21.77 and added my CAT ports and DAX speeds manually. Had me a cup of coffee and some radio fun. Now that the upgrade is over I'm glad it's upgraded
73 W9OY0 -
I did do the Uninstall as close as I cud and at this point the radio does come on line but DAX channels need work with running EasyPal. DAX is just not easy! Another dilemma appears to be that I had to update the 6300 b 4 using it with my WIN 10 LapTop..... but when I go back to my desktop cptr running WIN 8.1 it says I must downgrade 6300?????? Does this mean that every time I change OS I have to change downgrade 6300? Anyone run into this?
It means the laptop and desktop are sporting different versions of SSDR. SSDR exists in the radio as well as on the computer. If the versions in the radio and on the computer do not match you will get the down/up grade message. Simply normalize the versions across all platforms and this will be resolved
73 W9OY1 -
Tnx Lee - Makes good sense since SSDR versions in Radio must = Cptr SSDR version match.. Glad it was not OS dependent. Next step with WIN 10 LapTop is unscramble DAX / Ports.
Larry - you can always open a HelpDesk ticket and get assistance rather than hacking your way through the issue.1
Tnx - I try not to cry wolf & then if no go submit to Help Desk. One common question - do we do anything extra special like uninstall previous SmartSDR versions when up grading to latest version with no OS changes? It looks like programmers wud design next version to look at old version hard files (not settings) and replace old with new and delete old Icons.... U probably answered this many times - sorry abt that - but just in case..... Super thanks for Help Desk support!
You should never need to uninstall a previous version of SmartSDR before installing a new one since each version is its own independent version. However there are exceptions to the rule, like when a software change is made that is not backwards compatible and in that case, uninstalling first is a good idea.
- 255 Community Topics
- 491 The Flea Market
- 7.4K Software
- 137 SmartSDR for Maestro and M models
- 333 SmartSDR for Mac
- 241 SmartSDR for iOS
- 225 SmartSDR CAT
- 162 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 789 Maestro
- 42 FlexControl
- 837 FLEX Series (Legacy) Radios
- 737 Genius Products
- 394 Power Genius XL Amplifier
- 256 Tuner Genius XL
- 87 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 588 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 815 Third-Party Software
