Display problem SmartSDR
IK6DLK Fabrizio
I have this problem . Use Flex6500 SmartSDR for version 1.6.17 and Italien Windows 10. Some solution. TNX Fabrizio IK6DLK
What solution(matrix) you using at your monitor?0
There has been a complaint recently of this and I recall seeing that some computers in Windows 10 were missing a Font.
Here is the thread
https://community.flexradio.com/flexradio/topics/readout-of-frequency-only-shows-bottom-half-of-the-...
Good Luck
Dan -- KC4Go0 -
I think Dan is correct, the frequency readout font looks wrong. You need to install the "NapoliSerial Xlight Regular" font.0
Must be correct, after all Napoli is in Italy
Another problem I've noticed seems to be a scaling issue. I've been putting up with it for a couple years thinking it was eventually going to be addressed. Now I'm wondering if it is a problem only on my end. When in full screen, the panels on the right side of the screen can not all be displayed at the same time. The last panel EQ seems to be off of the bottom of the screen. Here's a snapshot.
Notice how the bottom of the EQ window is cut off and can't be read?
That is dependent on the resolution being used on your monitor. On my desktop it is fine and my laptop appears similar to yours.
This isn't a scaling issue. This is a resolution issue where the screen resolution / monitor size combination is not able to display the entire SSDR console window. We added scrolling capability to the side bar menus to compensate for this. You can scroll the windows down so you can see the bottom pane (EQ).0
Both the monitor and the video card are set to 1920 X 1080. The monitor is native 1080p.
I never could display all the dialogs on the right. Finally a scroll bar but its not easy to see, esp if you are not looking for it. But it does save multiple key strokes of turning tabs off and on and reversing the process. I guess it took a contester complaining about rate. Personally, I suggest removing redundant displays and making the dialog boxes smaller thereby removing the real estate issue altogether. But, that's why they made SDKs.0
I installed fonts , see in the picture , but the situation not changed .0
Have had the problem with no solution offered for the last 18 months!!
Will check out the Napoli serial font solution.
I have the problem, AGAIN. Napoli is installed in Windows but won't show correct in Flex I even uninstalled V1.6 and reloaded everything again but it is still showing incorrectly. Any suggestions?
For the issue described above, the SmartSDR for Windows application font did not install with the SmartSDR installer. This is usually due to a localized issue with the PC where a security suite incorrectly interprets the TrueType font as a possible attack vector. In these cases, you need to manually install the "NapoliSerial Xlight Regular" font.0
- 339 Community Topics
- 580 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 367 SmartSDR API
- 9K Radios and Accessories
- 893 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 702 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
