Physical KB function keys do not run the CWX macros
Tom Porada
I am able to run the CWX 'macros' just fine when I press the onscreen function key with the mouse while in SETUP but there is no connection to the physical KB function keys. Pressing the KB function keys does nothing.
Suggestions for a relative noobie? Didn't see anything on-point in the user guide,
SmartSDR 1.6.21, Win 10/64, Flex 6500
For the KB function keys to trigger CWX macros, the windows focus must be SSDR. ( assuming that something else is not interfering with the normal windos operation).
AL, K0VM
As Al mentions, if you happen to click to another program and do not click back on something within PowerSDR, PSDR is not the active program, the KB "F" keys do not work. Was scratching my head on that one day and found the solution.
As mentioned above, SSDR must be the active program. Ckick on your panadapter screen, and the function buttons will work.0
Hmmm...seems like I did not have SmartSDR's attention whenever I was trying to use the function keys. Just tried it and sure enough it worked as advertised!!
Case closed.
Thanks all.
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
