Physical KB function keys do not run the CWX macros
Tom Porada
Tom Porada Member ✭✭
edited September 2019 in FLEX-6000 Signature Series
I am able to run the CWX 'macros' just fine when I press the onscreen function key with the mouse while in SETUP but there is no connection to the physical KB function keys. Pressing the KB function keys does nothing.
Suggestions for a relative noobie? Didn't see anything on-point in the user guide,
SmartSDR 1.6.21, Win 10/64, Flex 6500
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited November 2017
    For the KB function keys to trigger CWX macros, the  windows focus must be SSDR.  ( assuming that something else is not interfering with the normal windos operation).
    AL, K0VM
  • Mike Sonn KF9AF
    Mike Sonn KF9AF Member ✭✭
    edited December 2016
    As Al mentions, if you happen to click to another program and do not click back on something within PowerSDR, PSDR is not the active program, the KB "F" keys do not work.  Was scratching my head on that one day and found the solution.
  • K2CM
    K2CM Member ✭✭
    As mentioned above, SSDR must be the active program. Ckick on your panadapter screen, and the function buttons will work.
  • Tom Porada
    edited March 2016
    Hmmm...seems like I did not have SmartSDR's attention whenever I was trying to use the function keys. Just tried it and sure enough it worked as advertised!!
    Case closed.
    Thanks all.
