Windows 10 taking control of dax
Trevor-EI2GLB
Hi All I have built up a new i5 PC to use with my 6500 i have it up and running on windows 10 an issue I have is I have no speakers or mic connected to the PC but its using the flex's DAX ports as both speakers and mic in, I'm only setting up everything so unsure what hassle this will cause me but has anyone seen this and is there anyway to stop windows assigning DAX for it use, Thanks Trevor EI2GLB
There is no way I have found to prevent this behavior by Windows. This is one of those features they implemented to make using sound devices easier. And for the basic user with one sound card and speakers and/or a mic connected, it does make it easier. For systems with multiple sound devices, not so much.
Since every motherboard comes with an embedded sound card these days, I just leave a cheap PC headset connected which is defined as the default recording and playback device.0 -
Trevor, you may take a look in the BIOS... with some motherboards you have the ability to disable the onboard sound device. Some you can some you can't but you might give that a try and see if it helps.
Good luck
David
KK4QOE0 -
This will not work. Windows will only see the DAX drivers and make one of them the default Recording and Playback devices. The intent is to prevent any of the DAX drivers in becoming one of the defaults.0
good to know.. thanks Tim0
And for the record, this is one "feature" of Windows that I would love to be able to turn off. It has caused grief for support for years when Windows grabs virtual sound devices like DAX and VAC used with PowerSDR.0
Amen!0
- 341 Community Topics
- 611 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 406 SmartSDR for Mac
- 265 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 197 FLEX-8000 Signature Series
- 919 Maestro
- 889 Genius Products
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 965 Third-Party Software
