Transverter Hook-up question
G4NRT
G4NRT Member ✭✭
This is a very simple question (I hope!).
I want to hook a 2m transverter up to my Flex 6500.
My transverter has two sockets (although I believe that it can be reconfigured to use a single socket).
How should I hook it up?  I believe that the best thing is to use the XVTR and "RX ANT IN" sockets.  Is this correct?
Is there a better / more correct way?
Thanks in Advance!
David G4NRT
  • Paul Bradbeer
    Paul Bradbeer Member
    edited June 2020
    That is correct, David. It is exactly how I use my 6500 and my Kuhne transverter. 6500 Tvtr socket for the TXIF and Rx Ant In for the RXIF. In fact, my GPSDO arrived yesterday, so I now feed a 10mhz reference to my transverter too...happy days! Paul M0CVX
  • G4NRT
    G4NRT Member ✭✭
    edited January 2018
    Cheers Paul! Just needed to check! Bravo Zulu!!
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited December 2016
    Yes, that eliminates the need for the internal relay in the transverter, and associated potential losses. It is just cleaner......unless you need the RXA port for a receive antenna on the low bands.
  • George KF2T
    George KF2T Member ✭✭✭
    Ken, have you noticed a performance difference between just XVTR and with both connections? Curious about how much difference it makes.
  • Ron Parsons
    Ron Parsons Member ✭✭
    edited January 2018
    David,
    You may be interested in the pair of articles the W0DHB and I have published. See
    https://community.flexradio.com/flexradio/topics/using-flex-radios-in-amateur-satellite-service
    Ron W5RKN
  • Ken - NM9P
    I was speaking from a theoretical position. I did have a Microwave Modules 2 meter transverter a number of years ago. It seemed that there was a bit more relay delay issue, and relay noise, when using a single input/output. I never measured other performance. But much of the reading have done in the past recommend using split IF connections if available. I don't currently have a high performance transverter installed at the station...only a cheap one I have been playing with occasionally.
  • G4NRT
    G4NRT Member ✭✭
    Thank you Ron. Very interesting articles - especially your one about FDX. Although I do not have the space to install antennas, rotator etc. here, I am very interested in the whole AMSAT thing - my pal Rupert G0TKZ got me interested initially and listening to the ISS talking to schools on amateur radio is big news here right now. David G4NRT
