Optimizing the Noise, ANF, SR, and NB settings with a 5000a .....
Brian Bedoe WD9HSY
Hi All --
Rather than re invent the wheel, I am wondering if anyone has played with all the noise blanking, noise reduction, SR and ANF setting to find a optimal settings? I am running a 5000a and a I7 desktop.
I know that these settings are "season to your personal tastes" but I have no problems starting from someone's "happy place"
A lot of these default settings were set back in the day when finding the happy middle was a compromise between the radio and computer processing power. With the advent of I7 machines and quad core I barely ever see my machine go over 20% ..... so I have some lots of head room to play with.
Any thoughts?
73, Brian
PS That 20% is running as many as 6-10 different things at once like PwrSDR, IE11 (on the DX Cluster, QRZ, and other windows) my logger, voice keyer, FLDigi ..... etc.
Any thoughts?
73, Brian
The default settings were selected as a good compromise for moderate noise sources. Select the correct noise mitigation feature for the type of noise you have and make small adjustments and allow for a little time so the DSP can do its thing.0
Tim, if you select default, does this change everything or just the function you want to set to default?0
There isn't a default selection, per se. When PowerSDR creates a new database, the DSP noise mitigation settings are set to the default values for the particular feature (NR, NB, NB2). From there you can change them however you like.0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
