Perceived incorrect response to display pan set max_dbm
Walt - KZ1F
radio Flex 6500
software 1.6.21
command sent C29|display pan set 0x40000000 max_dbm=-20.13
response received R29|0|
Expected response R29|0|-29.13
Why would the logic to process the change to max_dbm return a 0 status code but no new value?
The same phenomenon occurs for min_dbm as well.
The result of not having a string reply value is SetHighDbmReply(int seq, int resp_val, String s) fails with an "invalid reply string".
Thanks!
software 1.6.21
Thanks!
I looked at wireshark display of the data sent by ssdr and the data sent by XPSSDR. The only difference I can see is the total packet size. The actual cmd and line termination are identical. So really there are two issues: 1) why is the there a 0 response code but no data sent? 2) the answer to the first will point me to what I need to change such that the cmd reply is correctly formatted.0
---resolved---
The methods for setXXXDbmReply only have a value associated with the response if the return code is NOT equal to 0. When I saw the new value was being set independent of a response, which does come anyway, I assumed it was erroneous code to set the new value before verifying the change was valid so I commented out the setting of the new value in the initial setXXXDbm.
Tim, this can be marked as answered.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
