SmartSDR v3.3.32 and the SmartSDR v3.3.32 Release Notes | SmartSDR v2.7.6 and the SmartSDR v2.7.6 Release Notes
Power Genius XL Utility v3.6.24 and the Power Genius XL Release Notes v3.6.24
Tuner Genius XL Utility v1.1.8 and the Tuner Genius XL Release Notes v1.1.8
Meaning of the colors on waterfall when watching my own transmission ?
F4HPX
When activated I see my transmission on waterfall as well - that's great for monitoring
I was wondering if the colors from blue to red are reflecting the strength of my signal
and then why on some lower bands are quite blue/weak and higher green/yellow/orange?
Is that measure my output power? Antenna actual radiation quality ? Anything else ?
73, Thomas de F4HPX
73, Thomas de F4HPX
Thomas, to make it short: No, the signal shown when transmitting is not showing tx power or signal strength, but gives an approximate idea of the shape of your tx signal.
You'll find the official response here:
https://community.flexradio.com/flexradio/topics/tx-signal-on-waterfall-accurate
But you can easily measure output power, reflected power, SWR, Voltage and
PA temperature by using FRStack and enabling the meter window.
You can download FRStack here:
http://www.mkcmsoftware.com/Flex/Index
73, Alex - DH2ID0 -
OK Many thanks Alex0
THomas,
The signal you see in the WF during TX is the result of 'leakage' coupling ( mostly capacitance ) between the TX and RX. There is less coupling on the low bands as compare to the upper bands and therefor the difference in color.
AL, K0VM
I did not realize that Al. Thank you for that!
- 18.5K All Categories
- 132 Community Topics
- 2K New Ideas
- 279 The Flea Market
- 6.2K Software
- 5.4K SmartSDR for Windows
- 93 SmartSDR for Maestro and M models
- 211 SmartSDR for Mac
- 188 SmartSDR for iOS
- 180 SmartSDR CAT
- 113 DAX
- 321 SmartSDR API
- 7.8K Radios and Accessories
- 6.4K FLEX-6000 Signature Series
- 630 Maestro
- 29 FlexControl
- 777 FLEX Series (Legacy) Radios
- 407 Genius Products
- 240 Power Genius XL Amplifier
- 145 Tuner Genius XL
- 22 Antenna Genius
- 119 Shack Infrastructure
- 75 Networking
- 204 Remote Operation (SmartLink)
- 91 Contesting
- 306 Peripherals & Station Integration
- 87 Amateur Radio Interests
- 579 Third-Party Software
