ERROR PSH5V3-5.69
SP5LMT
When starting a radio error pops up. ( ERROR PSH5V3-5.67)
Has anyone had a similar problem in your Flex 6500.
Reset procedure does not work.
That could be a power supply error.
1) Check your power supply for 13,8V or change it.
I found this: https://community.flexradio.com/flexradio/topics/shutting_down_error_psh5v3_5_87_when_powering_on_sh...
2) Does the error still persist?
3) Then you should submit a HelpDesk support ticket here:
https://helpdesk.flexradio.com/hc/en-us
BTW I did'nt find a published error code list. Does anybody have one?
It would really be help to track down an error source!
Alex - DH2ID0 -
Power supply 13.9V
I checked on the two power supplies is the same. (Samlex 1235 and TEN-TEC-965 )
ICOM -9100 100W with two power supplies.0 -
This is a hardware error. I recommend opening a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 773 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 373 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
