What type of reset?
DrTeeth
I don't know if I have a problem or just need to do some type of reset. I have a persistence problem. I was on Olivia last night on 80m and then moved on to 60m. On switching back to 80m today, 80m has changed to CW 400 bandwidth instead of the DigiU it was on last night with 5K receive bandwidth. It keeps on happening and I have just reset things but it is not becoming more of an annoyance. When I switch back to DigiU, I have to set everything up again. Sounds like persistence is shot.
How do I fix this?
Thanks.
How do I fix this?
Thanks.
Guy,
Try installing FRStack (http://www.mkcmsoftware.com/Flex/Index), the MRU feature will display the different persistence settings. You can maybe see that way if it isn't saving it.
Someone else should comment further on this but I suspect it is one of the new profiles added with 1.6 that is responsible for resetting you filters. Not being an expert on the new 1.6 features ID suggest rereading the user guide section on profiles to see if something jumps out at you.0
To clear the persistence database, you do a full export of your profiles but UNCHECK the preferences option. The do a factory reset as documented for your particular radio, then import your exported profiles. This will return your radio back to its previous state with a clean persistence database.2
Thank you Tim.
- 384 Community Topics
- 648 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
